| (1) |
Valve Rocker Arm Cover Bolt |
| (2) |
Valve Rocker Arm Cover Bolt Grommet |
| (3) |
Cylinder Head Bolt (Short) |
| (4) |
Cylinder Head Bolt (Medium) |
| (5) |
Cylinder Head |
| (6) |
Cylinder Head Bolt (Long) |
| (7) |
Valve Stem Keys |
| (8) |
Valve Spring Cap |
| (9) |
Valve Spring |
| (10) |
Valve Stem Oil Seal (First Design) |
| (11) |
Valve Stem Oil Seal (Second Design) |
| (12) |
Valve Spring Shim (First Design) |
| (13) |
Valve |
| (14) |
Exhaust Manifold Gasket |
| (15) |
Exhaust Manifold (with Heat Shield) |
| (16) |
Pushrod |
| (17) |
Coolant Temperature Sensor |
| (18) |
Valve Rocker Arm Bolt |
| (19) |
Valve Rocker Arm |
| (20) |
Valve Rocker Arm Pivot Support |
| (21) |
Cylinder Head Gasket |
| (22) |
Valve Rocker Arm Cover Gasket |
| (23) |
Valve Rocker Arm Cover |
| (24) |
Oil Fill Tube |
| (25) |
Oil Fill Tube Cap |
| (26) |
Ignition Coil and Bracket Assembly |
| (27) |
Bolt |
