Application |
Type of Material |
GM Part Number | |
United States |
Canada | ||
Coolant Sensor Threads |
Sealant |
12346004 |
10953480 |
Cylinder Head Core Hole Plugs |
Threadlock |
12345382 |
10953489 |
Cylinder Head Expansion Plugs - Aluminum |
Threadlock |
12345382 |
10953489 |
Engine Block Front Oil Gallery Plug |
Threadlock |
12345382 |
10953489 |
Engine Block Plug Sealing Washers |
Sealant |
12346004 |
10953480 |
Engine Flywheel Bolt Threads |
Threadlock |
12345382 |
10953489 |
Engine Oil |
5W-30 Oil |
12345610 |
993193 |
Engine Oil Supplement |
Fluorescent Dye |
12345795 |
10953470 |
Exhaust Manifold Bolt Threads |
Threadlock |
12345493 |
10953488 |
Fuel Rail Bolt Threads |
Threadlock |
12345382 |
10953489 |
Ignition Coil and Bracket Bolts |
Threadlock |
12345382 |
10953489 |
Ignition Coil Bracket Bolts |
Threadlock |
12345382 |
10953489 |
Intake Manifold Bolt Threads |
Threadlock |
12345382 |
10953489 |
Oil Pan Surface at Front and Rear Covers |
Sealant |
12378190 |
Oil Pressure Sensor Threads |
Sealant |
12346004 |
10953480 |
Thread Repair Component Cleaner |
Cleaner |
12346139 |
10953463 |
Cleaner |
12377981 |
10953463 |
Thread Repair Cutting Oil |
Lubricant |
1052864 |
992881 |
