2002 Cadillac Escalade, Escalade EXT
1998-2002 Chevrolet Blazer
1999-2002 Chevrolet Silverado (1500 Series)
2000-2002 Chevrolet Tahoe (1500 Series)
2002 Chevrolet TrailBlazer
2003 Chevrolet Astro, Express
1998-2002 GMC Jimmy
1999-2002 GMC Sierra (1500 Series)
2000-2002 GMC Yukon (1500 Series)
2002 GMC Envoy
2003 GMC Safari, Savana
1998-2002 Oldsmobile Bravada
A rear parking brake retaining spring clip kit has been released for service. This kit consists of two parking brake hold down spring clips (2) and bolts (3).
Use J 46277 Rotor Removal Tool with J 6125-B Slide Hammer to remove the
rotor from the vehicle. Place J 46277 between the rotor surfaces in the
vent section of the rotor. DO NOT place J 46277 on the back side of the
rotor surface, it may damage the rotor surface.Notice
During rear brake rotor removal, it is possible to damage the parking brake shoe retaining spring clip. Order this new kit when replacement of the clips is required but the parking brake shoes do not require replacement.
The spring clip kits mentioned in this bulletin do not address any parking
brake concerns. Refer to the Parking Brakes sub-section of the Service Manual
for any diagnostic information.Important
Part Number |
Description |
Qty |
88936340 |
Spring Clip, Parking Brake Retainer Kit (S/T Models) |
1 |
88982879 |
Spring Clip, Parking Brake Retainer Kit (C/K, M/L Models) |
1 |
88935962 |
Spring Clip, Parking Brake Retainer Kit (G Van Models) |
1 |
Parts are expected to be available October 4, 2002 from GMSPO.
When removal of the rear brake rotors results in damage to the spring clips on vehicles under warranty, use the following labor operation in conjunction with one of the kit part numbers listed above.
Labor Operation |
Description |
Labor Time |
H2956 |
Parking Brake Shoe Retaining Clip - Replace |
0.7 hr |
Add |
To Sand or Grind DIH (ONE SIDE) |
0.2 hr |
Add |
To Sand or Grind DIH (BOTH SIDES) |
0.3 hr |
Add |
To Sand Brake Shoes (ONE OR BOTH SIDES) |
0.1 hr |
| GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information. |
WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION |
© Copyright General Motors Corporation. All Rights Reserved.
