| 12volts |
red |
ignition harness |
| Starter |
yellow |
ignition harness |
| Second
Starter |
| Ignition |
pink |
ignition harness |
| Second
Ignition |
white |
ignition harness |
| Notes: To avoid the check engine light
from coming on and possible damage to the automatic transmission,
the second ignition in this vehicle MUST be powered when adding a
remote start system. |
| Third
Ignition |
| Accessory |
orange |
ignition harness |
| Second
Accessory |
| Keysense |
| Power
Lock |
lt. blue |
brown plug at BCM |
| Notes: The BCM is located behind the
drivers side of the dash. The plugs on the BCM face towards the rear
of the vehicle. The parking lights are in pin A5 and the headlights
are in pin A11. |
| Power
Unlock |
white |
brown plug at BCM |
are in pin A11. |
| Lock
Motor |
gray |
driver kick panel |
| Unlock
Motor |
tan |
driver kick panel |
| Parking
Lights+ |
brown |
lt. blue plug at BCM |
are in pin A11. |
| Parking
Lights- |
white |
are in pin A11. |
| Hazards |
| Turn Signal(L) |
| Turn Signal(R) |
| Reverse Light |
| Door
Trigger |
BCM |
are in pin A11.
Use tan for the drivers door located in pin
B4 of the purple plug, and for the passenger door it will be a
orange in pin B2 in the purple plug or dk.blue/white in pin B11 of
the lt.blue plug, must diode isolate these wires. |
| Dome
Supervision |
| Trunk/Hatch
Pin |
| Hood
Pin |
| Trunk/Hatch
Release |
| Power Sliding Door |
| Factory
Alarm Arm |
| Factory
Alarm Disarm |
lt. green |
driver kick panel |
| Notes: Also found in the purple plug of
the BCM. |
| Disarm
No Unlock |
| Tachometer |
white |
ac |
ECM |
Notes: ECM is located near the battery,
down low, between the fender and the fan under the black plastic
cover. On the 4.3L, the tach wire is at pin 20 in the connector
labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located
at pin 10 in the red connector.
Diesel tach wire is white at
the cluster. |
| Wait to start |
dk. blue |
instrument cluster |
| Notes: See DirectFax document 1090. |
| Brake
Wire |
white |
brake pedal switch |
| Parking Brake |
| Horn
Trigger |
black |
brown plug at BCM |
are in pin A11. |
| Memory Seat 1 |
| Memory Seat 2 |
| Memory Seat 3 |
