| 12volts |
red |
ignition harness |
| Ignition |
pink |
ignition harness |
| Parking
Lights+ |
brown |
lt. blue plug at BCM |
| Notes: The BCM is located behind the
drivers side of the dash. The plugs on the BCM face towards the rear
of the vehicle. The parking lights are in pin A5 and the headlights
are in pin A11. |
| Parking
Lights- |
white |
are in pin A11. |
| Headlight |
white |
are in pin A11. |
| Trunk/Hatch
Release |
| Power Sliding Door |
| Speed Sense |
dk. green/white |
ECM |
| Notes: ECM is located near the battery,
down low, between the fender and the fan under the black plastic
cover. On the 4.3L, the VSS wire is at pin 3 in the connector
labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located
in pin 50 of the red connector. |
| Wipers |
| LF Window up/dn |
blue - brown |
A |
driver door switch |
| RF Window up/dn |
blue - brown |
A |
passenger door switch |
| LR Window up/dn |
| RR Window up/dn |
| Sun
Roof open/close |
| Sun
Roof Limit/close |
| Memory Seat 1 |
| Memory Seat 2 |
| Memory Seat 3 |
| Interface Module: |
Category: Immobilizer
Bypass |
Required: Yes |
Type: Passlock II |
| Part #: 556LW |
| Alternate Part1 #: 555LW |
| Alternate Part2 #: 555T |
| Alternate Part3 #: DesignTech
20402 |
| Alternate Part4 #: DesignTech
29402 |
| Notes: |
| Interface Module: |
Category: Door Lock
Interface |
Required: No |
Type: N/A |
| Part #: N/A |
| Notes: |
| Interface Module: |
Category: Combo
Interface |
Required: Yes |
Type: Data Bus |
| Part #: 457GW |
| Notes: Can use the 457GW to
bypass the Passlock II, but it will not control the door locks on
this model year. |
This wiring
information is being provided free of charge on an "as is" basis,
without any representation or warranty. It is your responsibility to
verify any circuit before interfacing with it using a digital
multimeter. Directed electronics, Inc. assumes no responsibility
with regards to the accuracy or currency of this information. Proper
installation in every case is and remains the responsibility of the
installer. DEI assumes no liability or responsibility resulting from
improper installation, even in reliance upon this information.
