Application |
Metric |
English |
General Data | ||
V8 | |
6.0L |
364 CID |
101.618-101.636 mm |
4.0007-4.0014 in |
92.0 mm |
3.622 in |
9.40:1 | |
1-8-7-2-6-5-4-3 | |
1.524 mm |
0.06 in |
Lubrication System | ||
4.73 Liters |
5.0 Quarts |
5.68 Liters |
6.0 Quarts |
41 kPa at 1,000 engine RPM 124 kPa at 2,000 engine RPM 165 kPa at 4,000 engine RPM |
6 psig at 1,000 engine RPM 18 psig at 2,000 engine RPM 24 psig at 4,000 engine RPM |
5W-30 | |
Camshaft | ||
0.025-0.305 mm |
0.001-0.012 in |
54.99-55.04 mm |
2.164-2.166 in |
0.025 mm |
0.001 in |
6.96 mm |
0.274 in |
7.13 mm |
0.281 in |
0.05 mm |
0.002 in |
Connecting Rod | ||
56.505-56.525 mm |
2.224-2.225 in |
0.004-0.008 mm |
0.00015-0.0003 in |
0.023-0.065 mm |
0.0009-0.0025 in |
0.023-0.076 mm |
0.0009-0.003 in |
0.11-0.51 mm |
0.00433-0.02 in |
Crankshaft | ||
0.020-0.052 mm |
0.0008-0.0021 in |
0.020-0.065 mm |
0.0008-0.0025 in |
53.318-53.338 mm |
2.099-2.1 in |
53.308 mm (Minimum) |
2.0987 in (Minimum) |
0.005 mm (Maximum for one half of the Journal Length) |
0.0002 in (Maximum for one half of the Journal Length) |
0.02 mm (Maximum) |
0.00078 in (Maximum) |
0.005 mm |
0.0002 in |
0.01 mm |
0.0004 in |
0.04-0.2 mm |
0.0015-0.0078 in |
64.993-65.007 mm |
2.558-2.5593 in |
64.993 mm |
2.558 in |
0.003 mm |
0.0001 in |
0.008 mm |
0.0003 in |
0.01 mm |
0.0004 in |
0.02 mm |
0.00078 in |
0.7 mm (Maximum) |
0.028 in (Maximum) |
0.05 mm (Maximum) |
0.02 in (Maximum) |
0.025 mm |
0.001 in |
26.14-26.22 mm |
1.029-1.032 in |
26.2 mm (Maximum) |
1.0315 in (Maximum) |
Cylinder Bore | ||
4.0007-4.0014 in |
Cylinder Head | ||
0.08 mm |
0.003 in |
0.1 mm |
0.004 in |
0.22 mm |
0.008 in |
120.2 mm (Minimum) |
4.732 in (Minimum) |
0.22 mm |
0.008 in |
Engine Block | ||
59.12-59.17 mm |
2.327-2.329 in |
58.87-58.92 mm |
2.317-2.319 in |
58.62-58.67 mm |
2.307-2.309 in |
0.11 mm |
0.004 in |
0.22 mm |
0.008 in |
234.57-234.82 mm |
9.235-9.245 in |
69.871-69.889 mm |
2.750-2.751 in |
0.005 mm |
0.0002 in |
21.417-21.443 mm |
0.843-0.844 in |
Intake Manifold | ||
0.3 mm |
0.118 in |
Oil Pan and Front/Rear Cover Alignment | ||
0.0-0.25 mm (Maximum) |
0.0-0.01 in (Maximum) |
0.0-0.5 mm |
0.0-0.02 in |
0.0-0.5 mm |
0.0-0.02 in |
Piston | ||
101.606-101.640 mm |
4.0002-4.0016 in |
0.018 mm |
0.007 in |
-0.022 to +0.03 mm |
-0.0009 to +0.0012 in |
0.07 mm |
0.0028 in |
Piston Pin | ||
0.012-0.022 mm |
0.00047-0.00086 in |
0.012-0.024 mm (Maximum) |
0.00047-0.00094 in (Maximum) |
23.997-24.0 mm |
0.9447-0.9448 in |
0.02-0.043 mm (Interference) |
0.00078-0.00169 in (Interference) |
Piston Rings | ||
0.25-0.41 mm |
0.01-0.016 in |
0.46-0.66 mm |
0.018-0.026 in |
0.25-0.75 mm |
0.01-0.03 in |
0.32-0.48 mm (Maximum) |
0.0125-0.0189 in (Maximum) |
0.53-0.73 mm (Maximum) |
0.021-0.029 in (Maximum) |
0.32-0.82 mm (Maximum) |
0.0125-0.032 in (Maximum) |
0.04-0.085 mm |
0.00157-0.003346 in |
0.04-0.08 mm |
0.00157-0.003149 in |
0.01-0.22 mm |
0.0004-0.00866 in |
0.04-0.085 mm (Maximum) |
0.00157-0.003346 in (Maximum) |
0.04-0.08 mm (Maximum) |
0.00157-0.003149 in (Maximum) |
0.01-0.22 mm (Maximum) |
0.0004-0.00866 in (Maximum) |
Valve System | ||
45 degrees | |
Net Lash-No Adjustment | |
12.16 mm |
0.479 in |
11.79 mm |
0.464 in |
Hydraulic Roller | |
1.25 mm |
0.05 in |
1.70:1 | |
46 degrees | |
0.05 mm (Maximum) |
0.002 in (Maximum) |
1.78 mm |
0.07 in |
1.02 mm |
0.04 in |
52.9 mm |
2.08 in |
45.75 mm |
1.8 in |
45.75 mm |
1.8 in |
340 N at 45.75 mm |
76 lb at 1.8 in |
980 N at 33.55 mm |
220 lb at 1.32 in |
0.025-0.066 mm |
0.001-0.0026 in |
0.025-0.066 mm |
0.001-0.0026 in |
0.093 mm (Maximum) |
0.0037 in (Maximum) |
7.955-7.976 mm |
0.3132-0.314 in |
7.955-7.976 mm |
0.3132-0.314 in |
7.95 mm (Minimum) |
0.313 in (Minimum) |
7.95 mm (Minimum) |
18.1-19.1 mm |
0.712-0.752 in |
