Draining
Fluids and Oil Filter Removal |
Crankshaft
Balancer Removal |
Engine
Flywheel Removal |
Clutch
Pilot Bearing Removal |
Oil
Level Indicator and Tube Removal |
Exhaust
Manifold Removal - Left |
Exhaust
Manifold Removal - Right |
Water
Pump Removal |
Throttle
Body Removal |
Fuel
Rail and Injectors Removal |
Intake
Manifold Removal |
Coolant
Air Bleed Pipe Removal Four Point Pipe |
Coolant
Air Bleed Pipe Removal Two Point Pipe |
Engine
Valley Cover Removal |
Valve
Rocker Arm Cover Removal - Left |
Valve
Rocker Arm Cover Removal - Right |
Valve
Rocker Arm and Push Rod Removal |
Cylinder
Head Removal - Left |
Cylinder
Head Removal - Right |
Valve
Lifter Removal |
Oil
Filter, Adapter and Pan Cover Removal |
Oil
Pan Removal |
Engine
Front Cover Removal |
Engine
Rear Cover Removal |
Oil
Pump, Pump Screen and Deflector Removal |
Timing
Chain and Sprockets Removal |
Camshaft
Removal |
Piston,
Connecting Rod, and Bearing Removal |
Crankshaft
and Bearings Removal |
Engine
Block Plug Removal |
Engine
Block Cleaning and Inspection |
Cylinder
Boring and Honing |
Crankshaft
and Bearings Cleaning and Inspection |
Crankshaft
Balancer Cleaning and Inspection |
Engine
Flywheel Cleaning and Inspection |
Piston
and Connecting Rod Disassemble |
Piston,
Connecting Rod, and Bearings Cleaning and Inspection |
Piston
and Connecting Rod Assemble |
Camshaft
Bearing Removal |
Camshaft
Camshaft
Bearing Installation |
Timing
Chain and Sprockets Cleaning and Inspection |
Valve
Rocker Arm and Push Rods Cleaning and Inspection |
Valve
Lifters and Guides Cleaning and Inspection |
Cylinder
Head Disassemble |
Cylinder
Head Cleaning and Inspection |
Valve
Guide Reaming/Valve and Seat Grinding |
Cylinder
Head Assemble |
Oil
Pump Disassemble |
Oil
Pump Cleaning and Inspection |
Oil
Pump Assemble |
Engine
Front Cover Cleaning and Inspection |
Engine
Rear Cover Cleaning and Inspection |
Engine
Valley Cover Cleaning and Inspection |
Valve
Rocker Arm Cover Cleaning and Inspection |
Oil
Pan Cleaning and Inspection |
Intake
Manifold Cleaning and Inspection |
Exhaust
Coolant
Air Bleed Pipe Cleaning and Inspection Four Point Pipe |
Coolant
Air Bleed Pipe Cleaning and Inspection Two Point Pipe |
Water
Thread
Repair |
Service
Prior to Assembly |
Engine
Block Plug Installation |
Crankshaft
and Bearings Installation |
Piston,
Connecting Rod, and Bearing Installation |
Camshaft
Installation |
Timing
Chain and Sprockets Installation |
Oil
Pump, Pump Screen and Deflector Installation |
Engine
Rear Cover Installation |
Crankshaft
Rear Oil Seal Installation |
Engine
Front Cover Installation |
Crankshaft
Front Oil Seal Installation |
Oil
Pan Installation |
Oil
Filter, Adapter, Pan Cover Installation |
Valve
Lifter Installation |
Cylinder
Head Installation - Left |
Cylinder
Head Installation - Right |
Valve
Rocker Arm and Push Rod Installation |
Valve
Rocker Arm Cover Installation - Left |
Valve
Rocker Arm Cover Installation - Right |
Engine
Valley Cover Installation |
Coolant
Air Bleed Pipe Installation Four Point Pipe |
Coolant
Air Bleed Pipe Installation Two Point Pipe |
Intake
Manifold Installation |
Fuel
Rail and Injectors Installation |
Throttle
Body Installation |
Water
Pump Installation |
Exhaust
Manifold Installation - Left |
Exhaust
Manifold Installation - Right |
Oil
Level Indicator and Tube Installation |
Clutch
Pilot Bearing Installation |
Engine
Flywheel Installation |
Crankshaft
Balancer Installation |
